TwinTurbo.NET: Nissan 300ZX forum - Check the lateral runout of the tire, the rim and the >>
ZUL8TR
on May 24, 2015 at 4:19 AM
shaking steering wheel under braking
posted by shawnc
on May 23, 2015 at 09:34 AM
the rotor on each side of the front? Note could have lateral runout of each separately or all. Lateral runout of the rotor will cause steering wobble under braking. While you are at it look into the radial runout of the mounted tire on the rim.
ZUL8TR in Orlando,FL
shawnc
09:34:24 05/23/15
looks as if all the obvious issues have been address. Just
jzack
10:53:59 05/23/15
What if the new MC isn't applying equal pressure to the
jzack
11:01:32 05/23/15
I'll check the TR again, but I did the replacement in '05ish
shawnc
11:13:02 05/23/15
Re: looks as if all the obvious issues have been address. Just
ttz'in (norcal)
13:53:04 05/23/15
Did you bleed system per FSM, which includes
ttz'in (norcal)
13:56:22 05/23/15
Bled correctly per FSM. Usually 88-90ft-lbs star pattern.
shawnc
14:31:51 05/23/15
Sounds like your on top of things, start with BMC.
ttz'in (norcal)
14:58:46 05/23/15
You didn't mention if you torqued all the lug nuts the
Zuberman
14:49:22 05/23/15
Check the lateral runout of the tire, the rim and the >> -
ZUL8TR
04:19:50 05/24/15
I re-torqued wheels to 75ft-lbs. The last alignment shop I
shawnc
09:15:54 05/24/15
My hotshot alignment guy here, (decades in the biz) told me
Zuberman
14:19:18 05/24/15
It has been said that most engine wear is at start up. >>
ZUL8TR
04:17:18 05/25/15
It depends on whether her husband has a gun ;-) (n/m)
Zuberman
06:22:09 05/25/15
Agreed. Those are things I try to explain to people. You run
Zuberman
06:23:25 05/25/15
